Hi all, on my 1997 s320 just rebuilt antenna gears, that the tab usually brakes off. Also replaced feeder tensioner and new mast. Fed mast in manually by turning wheel on motor, installed back in car but it only raises.
when you turn radio off it does not retract. I removed mast, turned radio on you can hear motor run for 12 sec. When you turn radio off motor does not run... any ideas ? control board ? if so where would I get one ...Thanks, Nick
