High Temp Readings -- 1981 300D
688 Views 4 Replies 5 Participants Last post by  p.lurkje
I recently thought it would be a good idea :eek: to drive from JFK Airport to the lower west side of Manhattan avoiding the highways. Took about three hours. Stop and go, more stop. My temperature gauge, which reliably remains at 85 C, climbed up to 120 C for quite a while, just below the red line. If I turned the motor off, when I restarted the car the temperature would climb right back up. Questions -- how to keep this from happening again? Any possibility of a warped head or other damage? The temp returned to normal once I got out of NYC.
Thanks,
Brian
'73 450SL, '83 300CD, '01 E320 4matic
I'd say you have a faulty fan clutch, or your aux electric fan is not working.
I'd do a coolant service with the correct coolant if it's been a while, and replace the thermostat. Cheap insurance.
Make sure the radiator is not gunked up, too. Old high mileage car, if it's the original, it could need a good cleaning.
1983 240d AT1993 e320 AT
+1 to this. In addition, better check your thermostat too.
