1 - 1 of 1 Posts
Hello I am a newbie on this and would appreciate some guidence.I just bought this 1989 300 e for $2500 put new tires on ,so have about $3000 invested.It seems to be a great car ands runs perfect on the highway. When you 1st start cold,it stumbles a slight bit ,then up on high idle-about 1100 rpm.after warm about 3minutes idle settles down to about 600 rpm everything fine until you shut it off.after it sits for 15 min or so,when you attempt to start,it will eventually start if you keep your foot on the accelerator,it stumbles and idles at about 1400 rpmin neutral and about 1000 in gear. It has new plugs,rotor and cap and passed smog perfectly when not idling high also new battery and alt.before I purchased it. Any ideas where to start? Thank you very much. Ken
1 - 1 of 1 Posts
