1990 500SEC
MY 1998 210 has strange problem the high beam wont work if i push it forward to leave it on but will work if i pull it back to flash it changed switch everything no good does anyone have wiring diagram for the light circut
THANKS FROM IRELAND
Mercedes e320 1995
THANKS FROM IRELAND
I HAVE THE SAME SITUATION.
DID YOU FIND THE PROBLEM?
THANK IN ADVANCE......
Sounds that way to me too Kent but the OP said he changed his and that didn't fix it.
1997 E320
In order to have the high beam stay on when you push the stalk, you must have the light switch (the one that allows you to turn on fog lights etc..) turned to the very right.
Dunno why they designed like that? But hope that helps!
