2006 MB C230 Sport Sedan
I recently acquired quite abit of money. I now have a question....
Should i get 2 xenon kits (one for low one for high) or a bixenon?
thanks
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
If money is no object, go for the real bi-xenon lights. The problem with putting xenons on the high-beams is that using them intermittently can cause the ballasts to fail prematurely. This would be an issue when using them in flash-to-pass or switching them on and off for oncoming traffic
2004 C230 Kompressor Sport Coupe
The Bi-X kits won't work well in our cars. They are set up for 1-filament bulbs, and the Bi-X kits are really for dual-filament bulbs. Unfortunately the factory Bi-X stuff is expensive to retrofit. You are probably best off with +50 bulbs in the high beams.
