1 - 11 of 11 Posts
300sl 1987
Hi,
I removed the climate control console for the wood restoration I am doing and I saw a black box reading:
'BOSCH crash sensor'
Could it be my 107 had once an airbag and the installation is all there? or have I got the wrong end of the stick and all 107's have that and it is used for...?
2010 Mercury Milan Hybrid, 1993 BMW 325i convertible
And 87 could have had an airbag. There would only be one, in the steering wheel.
300sl 1987
The thing is that the steering wheel has no airbag. Maybe it was replaced or God knows why.
Maybe the airbag went off and it was not replaced by a new one, though can´t see no collision evidence anywhere.
Was looking for clues of what extra components should I look for and where should they be if the airbag installation is indeed there...
Mistery...
Forum Administrator , RC Colas® & Moon Pies®
1981 380SL 151K: 2005 S500 116K
"Crash Sensor" is German for "Do not remove the climate control console for wood restoration."
Mistery...
Being a Euro/ROTW vehicle, perhaps they installed the airbag circuitry in anticipation of new laws? Or was the airbag required at the point of import in 1987?
560SL,380SL
I think the sensor controls the airbag AND the pyrotechnics for the seat belt lock-up mechanism - in a crash, these things fire off and lock the seatbelts in place. So, even if you don't have an airbag, you may have one of these.
strife2 to the rescue, again.
300sl 1987
Discussion Starter · #8 ·
Thanks for the answers. I will do some more investigation with the reference numbers.
If anybody removes the center console take a look and let me know if you also have one!
My 78 doesn't, but airbags weren't available in 78 so that's expected.
These are the pictures for the 86 (red) and 88 (black) 560SL. Note where the steering wheel mounts there is a redundant set of brushes at the bottom of the steering wheel mounting area. If you have these brushes then all you should need is a 560SL wheel.
Please be careful installing an airbag because you never know why it was removed if it did have one.
Also remember along with a 560SL wheel with airbag comes ugliness.
300sl 1987
Discussion Starter · #11 ·
Thanks a lot Roncallo,
will remove the steering wheel someday when I finish my other projects and take a look!
Cheers
1 - 11 of 11 Posts
