1 - 9 of 9 Posts
Whatsup Benzers
Just registered today, My dad just got me a 98 E430 a few days ago as a replacement for a 2000 540i I totalled. Just wondering if theres any known issues with the car I should look out for
Also, Ive got a few questions
When I accelerate hard, why does my front end feel like its taking off into the clouds?
My passenger side window decides to go up sometimes, then return back to the halfway point. Why? Bad switch?
My console says "Lamp Defective", why? I dont see any lights that are out.
The light switch can be pulled out twice, I know the first time activates the foglamps, but what does the 2nd pull do?
Is the rear view mirror power controlled? If so, where is the switch for it?
Why do I get freezing cold air out of one vent, and the rest of the events feel like blow dryers? ( My 92 S class has this same issue )
Does it have rain sensing wipers? Cause when I put the wipers on the first setting, sometimes they'll go really slow when its not raining much, and other times they speed up to compensate for more rainfall
Is there a way to turn on the light from the rear seat?
What is up with this key thing? What happens when my battery goes dead? Can I still start the car?
Also, the front headlamps look goofy at night when you have xenons on the big ovals, and regular lamps elsewhere. I wanna put xenons in the fogs and the smaller ovals, what kind of bulb should I use, and is it easy to access and change?
And finally, my car has the alloy wheels ( Id assume 16 inch ) and they look okay and all, but what are some nice mercedes benz wheels of a larger size? ( Perhaps AMG wheels ) for a relatively okay price. I dont care if theyre not OEM, I just dont wanna drop too much into this car because its an "In-between" car until I find a 745i.
Heres some pics for those who are interested
The 1998 E430
And the car it replaced
2000 BMW 540i
Some classy wheels like that, for the benz, would be ideal.
Taken moments after my accident ^ :crybaby2:
My 1992 400SE
I would recommend the "search" button on the forum page. Most of this stuff has been covered many times in detail. The rest of it is in the owner's manual.
I don't think that converting other bulbs to xenon is covered, because it's essentially impossible.
My Two Left Feet
Welcome, hope we could see some pics....I had teh same issue last night for the first time. it was wierd but I turn my engine off b4 closing windows so I assumed I didnt press the button all the way untill I just held the button all the way till it closed...
· W210 Moderator
99 E320
** i'll PM you separate info
** what the heck does that mean? try be a little more clinical in description
so we can understand
** if you've only pressed the UP switch one time and the window action
results in up and down motion, you probably have the notorious window
regular problem. replacement is a $200 or so (DIY job). yes, bad switch
also....so do thorough check of both
** then keep looking. check brake light (not running light). check if you have
center brake light. check corner/fender lights. check high beam, reverse light,
and city light bulbs
** fog light in rear....pax side
** outside wing mirrors powered only. not inside.
** check the uni and duo-valve.
** option. you'd see the sensor on windshield opposite the inside rear mirror.
** read manual. yes you still can start car. battery powers convenience features
for opening/closing door, window, roof
** i'll let you do this on your own because it's more dangerous and ill advised.
** MB rims use lug bolts, not lug nuts. there are different size bolts.....diameter,
length, and ball seat radius. when you select rim, you must determine if the
offset is sized properly for your car and....if you can find the correct bolt for it
to match your car.
http://www.alloywheelsdirect.net/mercedes_wheel_fitments.pdf
Wheel Offset Calculator
Tire size calculator
Tire Dimensions Made Simple - Discount Tire Co.
New Used & Refinished Factory Aluminum Rims Wheels MERCEDES BENZ 230 240 240D 280 280S 280SE 280SEL 280C 300D 300CD 300TD 300SEL 300SD 380SE 380SEC 380SEL 420 450SE 450SEL 560 560SEC 56SEL OEM Alloy Used Wheels Rims Sales 1972 1973 1974 1975 1976 197 (change/scroll last digit in link from 1 to 2 to 3 to 4....)
** some of your questions are very basic. do you have copy of the owner manual?
The 1998 E430
TinyPic - Share The Experience!™
2000 BMW 540i
My 1992 400SE
Discussion Starter · #6 ·
I mean, the front end goes up and the rear end dips, in a very exxagerated fashion. More so than any other car Ive had. I guess benzes just have soft suspensions
yes it will go up all the way, then decide to come back down to about halfway. I can still get it up, 200 dollars isnt worth it to me. I just have to hold the button down and keep pressing.
havent checked all those, will do, thank you
fog lamp in rear???
thats odd, my 92 has power controlled rear view
what is that?
is the sensor a little pyramid shaped piece of black plastic? if so, badass, I have it.
Dont have the manual. but thats good, how does the battery charge? In my bimmer it charged everytime it was in the ignition.
hows it dangerous, they dont have to be real, its more a design thing then a practicality thing. the main xenon lamps will do the job
to match your car.
http://www.alloywheelsdirect.net/mer...l_fitments.pdf
no
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Suggest you break out the owner's manual and read it. Most of your questions are answered there. If you need one, they are available from MBUSA at reasonable prices.
Len
2002 ML320
Yeah read the manual.
Since you have Xenons... you have rain sensing wipers... for the "goofy" looking city lights check out the "xenonmatch" bulbs at this site:
Hoen high performance halogen
And lets see some pics!!!
1 - 9 of 9 Posts
