C230 2000
Well I just got my car fixed yesterday, changed MAF, changed spark plugs since cylinder 4 was misfiring, welded a peice of exhaust that was loose and I also got a shield tighten so it would stop making noise... Man was I happy! I got out and took it for a test drive, no more check engine, everytime was running real good... too good to be true...
Today, I get back in my car and guess what! my check engine light was back on... go to hell check engine light!!!!
I check my codes and I get
P0341 Camshaft Position Sensor Circuit Range/Performance
and
P0455 Evaporative Emission Control System Leak Detected (gross leak)
So now what, what did my car get into now!? :surrender:
2001 CLK55 AMG, 2002 C32 AMG
i would recommend clearing the codes and see what comes back, but it looks like you need a new camshaft postion sensor. this might cure your other code as well, but im not sure, they look like two seperate issues to me.
'99 2.3L Kompressor
Could you maybe have done something to the camshaft position sensor wiring while doing the other work?
Your avatar says you have a 2000 c230 and your sig says you have a 2002 c 230. Which is the problem vehicle?
C230 2000
My mistake, it is a 2000 C230!
And i did erase the codes and no more check engine :) problem fixed!
