Hello, I need a little help, actually, a LOT of help.
I have a neighbor that has a 2001 C320. She bought it over a year ago, used it for about a month and left it in the garage, sitting!! She said, “I haven’t turned it on since”.
She asked me if I could help her get the car to turn on. I said, I can try. Well, there’s several issues. For one, I have never worked on Benz, only on American cars. Two, I have never worked on a car that’s been sitting for over a year.
So what I’ve done so far. I tried to turn it on, dead! Battery didn’t charge, so I got a new one. Installed it after removing the cover, which looks like it has some kind of filter on it.
So good so far, checked the oil, still has oil and shows the right amount. It has antifreeze, ok, time to start it up and it turns but does not turn on. Ok, so go to start it and she says, oh, it doesn’t have gas, ohhh okkkkk. So we put about a gallon she had in the garage for her lawn mower. I try to start it again and it turns but does not turn on.
Do I need to replace plugs? Or what should I do to get it to turn on. I attached a picture of the console.
Suggestions?
Service B??
So the engine rotates but does not fire? It could be a fuel pump issue, or a bad Crankshaft Position sensor. There is a Schrader valve on the fuel rail where you can check pressure. If there's no pressure at all, then it may be the fuel pump. If it has pressure, then I'd suspect a bad CPS.
Rodney is it not the case that a bad CPS will cause the ECU to shut down the fuel pump? Thus giving no fuel pressure and the false appearance of a bad fuel pump?
That's correct - as a safety feature, if the CPS provides no signal, the ECU assumes the engine has stopped so it shuts off fuel. However, it does energize the fuel pump with the ignition switch in order to prepare for starting, so there should be some pressure during cranking if the fuel pump is working.
OK ,thanks for that ,it all makes sense now.
