I have a 87 190 and the emergency and turn signals are not working...I checked the fuse and checked to be sure there was 12v going through it...
Any ideas? Where is the relay? Anything that I should look for?
Thanks in advance...
'85 2.3-16 '99 C280 '11 GLK350
Check the hazard switch. The flasher relay is the big one, farthest back in the fuse box.
'86 190E 2.3L
make sure the hazard switch is pluged in all the way under the shifter area. also, you might not know it but, if a blinker isnt working, neither will the hazard switch.
'86 190E 2.3L
Just as we suspected from our years of detailed research of blinkers and their strange behavior.....[:p]
