1 - 1 of 1 Posts
1982 300SD, 1984 380SL, 1997 E320, 2008 R350
What I have is a US 1984 380SL body with a US 1984 500SEL engine.
Please, help me understand this table http://www.startekinfo.com/StarTek/outside/11883/PROGRAM/Engine/107/M116_38/15-501.pdf
Am I correct in unerstanding that I need to set my timing on a warmed up engine to TDC with vacuum off and check that it advances to 11 - 15 degrees at 1500 rpm and to 22 - 26 degrees at 36 rpm? And, with vacuum connected it should be at 15 - 17 degrees at idle?
Thank you in advance.
1 - 1 of 1 Posts
