1983 300CD turbo.
'83 300CD with original becker tape deck.
recently the radio reception has gotten static-y and volume doesn't go as high as it used to.
i figure the volume is probably due to not getting proper reception since it works fine when tape is playing.
the antenna goes up and functions, just not getting clean signal.
any ideas.?
i tried pulling the deck and unhooking all plugs and re-connecting. no luck.
any help would be appreciated.
1771 Cugnot Steam Wagen
Do you know if these have AMPs? If they have AMPs it might be your problem. You could always send it into Becker for repair and have them solder the iPod AUX cable in there too while you're at it.
1983 300CD turbo.
not sure.
would that only affect the volume for radio?
the tape volume works fine. its the radio volume/reception thats lost quality.
