Mercedes 300se w126 (1990)
Hello members
my rear doors window switches poped out because the pins in the switch surounding case that holds the switch in to place broke.
I noticed that the surounding case could be separeted from the switch.
My question:can I buy the surounding case without the switch?
if yes what is that P/N or part description and where can I find it?
thanks
Yossi
2012 CL550 4MATIC Coupe
Post a picture of the part in question and I will look it up for you.
Hello members
Photo attached as my rear doors window switches poped out because the pins in the switch surounding case that holds the switch in to place broke.
thanks
Yossi
'82 Euro 500SEL, '85 Euro 500SEC AMG WB Cabriolet,'86 Euro 500SEC RUF
Yossi,
Those should be available from the dealer or from a breaker's yard(Junk Yard). You can paint them to match.
I'll look up the part number and post it here.
EDIT:
Look on the back side of that cover there should be a part number cast in there someplace, but I think this might be what you are looking for, but I don't know which color it is.
A000-821-06-3
You can PM me your VIN and I can do a further check, but without the VIN this is what I came up with.
Not for the later 126's they are surrounded by wood, but they fit into the surround. same way the late 126 Sedan visor clips are different from the earlier ones in that they are larger and more of a squared off base.
