1 - 8 of 8 Posts
ML 350
You know the ones I mean. Two above each front seat and one above and two behind the rear seats. They each appear to accomodate some type of insert which permits mounting of some type of hook or other accessory.
So my question is where do you get the inserts [and what are they called]? I would very much like to be able to mount some hooks in the rear inserts so I can hang some bicycle wheel covers [I was able to do this pretty easily in my old ML320]?
Thanks for any help!
'10 Mbz S550, '03 Mbz C240, '03 Audi A4 2.0 Stroker, '08 Lexus SC430 PB Edition, '07 Prius
I Think It's For Those With The Comfort Package, Which I Have, They Give U A Net That Connect There And Covers The Rear.
2006 C55 AMG and 2007 ML63 AMG
Those recessed holes are the mounting points for the cargo divider net, which is, IMO, a fairly worthless apparatus. I believe that the cargo mesh divider system may also make use of the mounting holes, but I'm not certain about that.
Soon to be owner of ML 320 CDI
thinkman and smackjack are absolutely correct re the use. I thought it was a bit useless, but used it for the first time and found it pretty handy. We stacked up the storage section, well above the seat level and this does provide a real safety measure in such cases. It is sturdier than it looks and if it stops items from flying forward in an accident and striking a passenger, not such a bad thing. Like thinkman, got mine with the Comfort package.
It Should Of Come With A Bar And A Folded Leather Case Looking Package, It Might Be In The Spare Tire Compartment. Here's How U Know If U Have Comfort Pack, Do Ur Mirrors Fold?
1 - 8 of 8 Posts
