1983 Mercedes 300SD
model:1984 300SD Turbo Diesel
problem: glowplug system will NOT operate with key.
question: I want to operate the system with a toggle switch. Which of the million and two wires do I want to connect to? or should I connect it directly to the fuse in the control unit (the flat fuse)?
THANKS EVERYONE!!
1987 420SEL
Have you changed the relay? Why does the system not work with the key? Have you checked all the glow plugs?
You can by-pass the timer relay and connect another relay, operated by a toggle switch, to keep the plugs on for as long as you want. I'd use a momentary switch, so your finger has to be on it, rather than having the possibility of leaving the plugs on and getting the whole system upset.
Do not connect a toggle switch to that fuse.
