At a complete loss, need help from someone who has faced this before.
New plugs, distributor cap and rotor.
Thanks.
Thanks.
I've heard good things about thisTechron Concentrate does lower emissions but may not lower enough to pass the test. If you use mostly Chevron gasoline you should be getting enough of the Techron in the gasoline such that you don't need to use the Techron Concentrate. If you have used some inferior gasoline and all of a sudden used Techron Concentrate, there might actually be a short period of time when deposits that may have formed in your fuel system are being loosened by the Techron and driveability may suffer a bit until all the deposits are cleaned out of the system.
Using Techron for a time before emissions test may lower hydrocarbon emissions because it cleans valves and combustion chamber deposits. We don't recommend going for smog test while Techron Concentrate is at its highest dosage in your tank. Run a regular tank full of gasoline thru first.
Before you go in for an emissions test, it is best to make sure the emission control system, especially the catalyst, is fully warmed up You should drive a few miles on a freeway or highway at cruising speed to ensure everything is warmed up before you take the car in for testing.
