I have a 1962 220Seb convertible and I need a brake overhaul. Can anyone give me a part number for a caliper that will replace the original ones on the front. Mine are siexed and apparently cannot be rebuilt. Is there a cheaper "upgrade" to a more modern set of calipers and rotors?
Also, I need to replace/rebuild the brake booster. Any ideas on where to find one or an alternative to interchange. I drive the car so I am not hung up on orginality (particularly on safety items like brakes).
Any help would be greatly appreciated.
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
I looked at Autozone or Advance Auto and they have calipers by Cardone for sale. Check them, you need calipers with the central brake pipe connection. Most likely, you have a single circuit brake and a remote mounted power booster. Please take a picture of your brake components. If you have the T50 remote power booster, repair parts are available.
1972 300SEL 4.5, 1971 Citroen DS21, 1995 Jaguar XJS
I believe the later ATE calipers are a bolt in replacement for the 3 piston girlings your 220SE has. As wbain said make sure the pipe connection is the same...
