My rear window wont go up. i can hear the motor trying to push it up, but nothing. <br>
<br>
How can I open the rear door panel to pull the window up so i can park my car safely at night!<br>
<br>
Any tips, instructions or website would greatly be appreciated.<br>
<br>
Thanks for your help
Discussion Starter #2
I have had this same problem it is the window switch. If you push the switch down and to the right it will move it a little. do this until you get it to the top then press the one touch to go all the way up. You might have to do this once or twice in either direction, but once I did it, it was fine. Spr
Check around the door to see of there are any screws, if not, check if you can pull the door panel off as you can in many Mercs. It sounds as if the spring/cable has been damaged and needs replacing.
