85 300 SD
i have an 85 300sd(126 chassis)and i need to know what function each of these wires has...if anyone could tell me,id appreciate it...
red wire-
brown wire-
black wire with yellow stripe-
grey wire with purple stripe-
and in the following pic is a brown wire with blue stripe,thats in a sleeve that just says
"radio" on it
85 300 SD
Discussion Starter #2
this link might help; http://www.harmanbecker.us/connect.jpg
the brown striped is ground,...
the brown striped is ground, bolted to the radio,
brown is ground in the 4 pin connector,
there is also constant 12V for memory,
ignition plus,
and one wire for the dash bord lights.
85 300 SD
thank you very much...ive been searching for these answers for a while...you saved the d...
thank you very much...ive been searching for these answers for a while...you saved the day,horst[:D]
