2001 E320 Wagon
I'm in need of some assistance- how do you get into the rear hatch to replace a bad fog lamp.
Also, I've been having reoccuring lamp problems- left side blinker and break lights keep failing- replaced twice in a month. Any suggestions as to why this may be happening.
W211/W210 Estate /W209/W208
The Rear Hatch cover comes off Very Easy!
Several of the Two part Push in plastic clip. and the cover at the handle.
Sounds like the bulb holders are going..Inspect them for a loose contact..They melt and cause the problem.
2001 E320 Wagon
Thanks for the response- When you say several of the two part.....you mean I can pop off the plastic clips- are there screws underneath? I'll check tonight.
Yes- I noticed that the clips seems sort of loose- I'll order some replacements.
You da man!!!
