1987 190D 2.5 Turbo, 1999 Mercedes Benz C230 Kompressor, 1986 190D 2.2 397,000miles
I just bought a '87 190d turbo. I want to change the auto transmission filter, i have been reading some threads and it does not sound to hard. Are there any tutorials on how to do it? Also how or when should i do the flex disks? And how much trans fluid should go in it when i change the filter. - thanks, ben.
1985 2.3 190E 208K and 1992 2.6 83K
This thread covers more than simply the tranny fluid/filter change, but it has pics and so might be helpful. Simply disregard the K-1 spring related stuff. The important thing is to drain all the fluid by rotating the engine in order to drain the torque converter and draining it. This thread has pictures about that which is especially helpful. Note that the thread recommends a specific direction for the engine to be rotated ("rotate clockwise when facing the engine").
DIY Mercedes 722.3 722.4 722.5 Transmission K1 Piston Spring Repair Kit Install - 190 Revolution
Consult the manual for your car regarding fluid capacities. There are also manuals online linked in this forum. Go to the Read First FAQ for the link to them.
'98 E300, '10 GL350 Bluetec
Ben:congratulations on your purchase of an excellent variant of the W201 car. You will need about 7 litres of ATF.
