1982 280ce Australia
Can someone tell me how to remove the rocker panel cover [ trim] on the door threshold on a w123. It's the one you step to get into the vehicle.
Any help would be appreciated.
.................... ~'84 300D~~~~~~~~ ~~'85 300TD~~~~~~~ ~~~W123(s) Galore~~~
Grab it from the bottom and pull it off.
To put it back on usually you can use the same clips. Hook it on the tops of the clips first then use a rubber mallet to tap it down.
YUP
1984 300D
If you go on eBay and look up the parts you can see what the clips look like.
On the Doors the trim has a metal clip that slides into a hole on the Door on one end. If you grab that and pull you will damage something.
Look for or see if someone will post a free site that has the W123 Service Manual.
