1 - 1 of 1 Posts
ML 320 cdi 164 2005
hi all i have a mercedes sprinter 313 cdi 2004 which had a new steering rack fitted when i got it back the abs esp and wheel light are on,the dealer tried to re set it and told me it was the angle sensor,they fitted it it didnt cure the problem so then told me the wrong steering rack fitted as they could not get within the tolorence for straight ahead, i think that when the non mercedes garage fitted the rack the didnt line up the steering column correctly on the splines or turned the steering wheel before putting it onto the rack,
my question is in the straight ahead position looking at the steering wheel where should the cut out be for the angle sensor to locate on the column ie 10 o clock 12 o clock etc really would greatfull if someone can help, mercedes wont tell me
regards ziggy
1 - 1 of 1 Posts
