2001 230 SLK
Up early this am to wash and wax SLK 230 manual 2001.
Car will not back up,
Acts like parking brake stuck.
Jacked up rear and left drivers rear seems locked. Jacked up passenger rear and wheel turns freely?
Ideas,
Running 17 AMG with factory 12mm 1.5 lugs,
Brake handle releases and no brake lights flash on dash.
2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
That could be the problem... If you had the brake on over night and there was some moisture, could be the brake is stuck to the drum.
If you're on a flat surface, try and rock the car fore and aft manually, it might break loose.
The other alternative problems could be bad.
2001 SLK 230
if u put it in Neutral can you push it?
--Deathy
