OK, I've been tuning up the newly acquired 1987 300SDL. All has been going OK, but this one has me stumped.
Background - The car has 275K Miles. It has been starting great for me every day in the week since I bought it. I know the fuel has some contaminants in it (i've changed the primary filter 5 times - also changed the large secondary filter yesterday just before the seafoam procedure). The sediment seems to be less and less the last few days so I think most of it is gone. Not sure if this is contributing to the problem or not - but thought I would mention it.
Yesterday, I removed the vacuum line from the top of the blue flying saucer looking thingie (located on the driver-side fender well area under the hood). I placed the vacuum line in the bottle of seafoam and allowed it to slowly take-up the liquid into the system. After about 20 seconds it sounded as though the engine began running much smoother. I didn't see much smoke out the back of the car - but could smell the seafoam from exhaust so I know it was getting to the engine.
After emptying the bottle into the system, I let the car run for a few minutes and shut it off. About 5 minutes later I restarted it (started great) and went for a little spin. Seemed a bit peppier (but still a bit of lag). At any rate, I parked the car and went in to have a celebratory beer. About 2 hours later I was going to take the car for another longer drive and it wouldn't start. It turned over fine (even started and ran very rough for a few seconds - exhaust smelled very rich or perhaps more seafoam?). It tries to start but sounds like it is starved for fuel. I cranked for about 30 seconds, waited a minute and cranked again for another 30 seconds. Again, it seemed to wanna start - just not quite.
I didn't suspect the fuel filter as it was running fine before I shut the car off. Regardless, I changed the primary filter again to be sure it wan't that - to no avail.
I assume that if I keep cranking (re-prime) it will fix the problem, but my primary concern is that the seafoam may have not been completely burned off in my short drive/run time and it has now settled into the low-point of the vacuum system. Do I risk hydro-locking if I try to keep cranking?
If not, anyone have any suggestions as to how best get her up and running again?
