So I was carrying some ski's in my E320 and during the trip had to slam on the brakes.
To make a long story short, one of the skis came flying and hit my radio unit.
The Little display is now disconnected from my car with a ribbon attached to it, so I can now see the tape player ( which I never knew I even had). Is it possible to put this display back??
Ps can put up pictures if needed
A EBay replacement will be $160-$200
There are replacement units on eBay for $160-$200, if you go that route make sure the seller can give you the new radio code.
The unit slides out, you can get the metal "keys" for under $5 (check other postings on the board) - then the unit is plugged in thru a plug and play harness, really easy to remove.
Becker also offers a repair service, you can do the google and give them a call.
Good luck !
2004 clk500
i have my original deck i can sell, i put in a after market one. if you are interested pm me. if its not that badly damage maybe you can put it back together. will have to see the pics though.
