Martin i am us at posting videos .But if you put this in to Google search engine -
How To Remove Centre Console CL500 W215 you will find how to do it .
I put it bro but they either show a different car or skip the parts where they show how to do it..
w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Did you look into the very bottom of the storage bin behind a finished layer of felt-type material (typically, there are 2 hex nut bolts) or 2 bolts screwed on a metal angle clip that is part of the center shell itself, along the inside edges.
EDIT: You may need to get into the rear seating area and grab the center console, lift up and pull back to remove it. They may have used channel snap clips on the bottom of both sides to lock it into place rather than screws/bolts inside the storage compartment.
