G
Guest
·Has anyone had these problems that I'm having with my CLK 430 (2001)?<p>1) <p>a) Every so often, I will switch from radio to CD, and nothing will be playing. I check the track forward, and can "fast forward" through the CD or switch tracks, etc., but hear nothing. I have to "reboot" the car by turning the engine off & restarting. Then it works.<p>b) Same thing will happen with the voice command for the cellphone, I'll hear the "beep", and after my request I don't get a voice follow up (e.g. "The number please"). It will work after "rebooting" the car. <p>c) Same problems happen in reverse from using the cellphone and switching back to radio or CD. "Rebooting" works.<p>2)<br>a) Also have problems with my side view mirror not coming fully back to its position when going from reverse to drive. Have to manually adjust<p>b) As well, sometimes the mirror will attempt to move into a position that it mechanically can't acheive, and "snap" repeatedly.<p>-- With both the problems above, I took my car into the dealership _twice_ and both times, they wouldn't / couldn't fix, because they "couldn't replicate the problem" -- I've contacted Mercedes directly, and they just referred me back to the dealership.<p>3)<br>Twice in 2 months the front air dam has fallen off. First time it was while it was at the dealership, but the second time was just 2 days later. Since I've owned this car, I've only once parked close to a low concrete parking barrier. The dealership said that "this happens all the time", but I think it's BS and want to find a way to fix it permanently.<p>Sorry for the lengthy posting, but if anyone can give some ideas as to computer problems / design flaws, please do!<p>
