1991 350SDL 2004 G500
350SDL with a 300SDL engine
This came out of nowhere yesterday. We did an oil change and a light hosing down of the engine (With degreaser) I didn't drive it until this mourning.
Everything works fine from a standstill until the first shift of the transmission. From there on out there isn't much power and it won't shift again until I reach much higher RPM (above 3000). Cruising at around 40 then pushing it does nothing, slow acceleration at first but eventually the rpms will surge up to 3500-4000 but still no power.
We're stumped, please tell me that someone here knows whats going on.
84 300sd 85 300 sd 85 300sdl 03 745il bmw 65 mustang 67 mustang, 86 mustang cvt, 91 dodge stealth
Change your fuel filters first. This is a typical problem with 300 sd and if this fixes it you will know next time what to look for.
I read about that here on the forums and i'll be picking up the filter before I get home today. I'm curious though, if it is the fuel filter, wouldn't I have noticed a gradual loss of power over time instead of having it happen all of a sudden?
MERC v126 300SDL & w126 280s
you can also check if your car still might have the trap oxidizer which was recalled by mercedese benz....the symptoms u have mentioned usually are caused by the oxidizer and after its removed the car works perfectly
