Can someone please put me straight.. I've got a 59 plate 115 with a sound 5 radio/CD. it also has the aux jack fitted. I want to swap it for a new style Audio 20 unit.
I know I need a quadblock adapter, but do I need an antenna adapter and will my original aux cable be OK?
I've tried contacting the guy selling it, but his written english is....well.... not like wot it used 2B in my day, mate innit! Also the Audio20 is £290 and the cables are £110!!!! Obviously I dont want to spend £110 on a load of cables I dont need..
Thanks in advance..:confused:
Hi, you need an antenna adapter, I have one forsale.
You need a quadloc adapter unless you can solder.
You also need a bluetooth antenna.
You will need a mic and a 3.5mm adapter with a white plug that fits the new quadloc.
£20 for the antenna adapter, it is new.
Why are you paying £290 for audio 20?
Cheers Ian.. pm sent
