Hello Benzworld! I have a mercedes clk 430 2001 but none of the windows will operate. There is no power or any attempt to roll down when the button is pressed. The fuses are good and Im not quite sure where else to look. Any advice?
W221 & Audio Moderator
2013 S550
It may be your door control module - they are particularly sensitive to water. Do the switches that are on the other doors control their respective windows?
Still in trouble
So I checked specific fuses for the windows.. everything is good. I took a look at the door control module in the drivers side door. Looked ok to me, I un and replugged it as some threads on here say to do that. But every switch on the center console doesn't work. And advice or leads on people with similar problems?
2013 S550
If your center console switched (including those on the center dashboard) don't work, it is a bad SAM.
