I have 1999 E320, and when I installed 17 inch AMG monoblock wheels, it does not seem to fit perfectly. The wheel still shakes a little even though I screw the bolt tightly. Somebody told me the wheel spacer will take care of the problem. Is it true?
Need some advice.
sounds like you wheel is not fitting hubcentric you will need to get some rings the fit over the hub you can probably get them from the dealer. I am having the same issue with some brabus wheels and ordered the rings and some spacers from brabus to bring the wheels out 10mm. good luck! if all else brabus only wants $10 for each ring they may fit?
