1984 MB 190e, 1978 MB 300CD, 1985 MB 300TD, 1976 MB 240D, 1979 Chevy Truck
Well I live in the northeast and it is beginning to be the coldest part of the year around here. I am stumpted on my 190e no heat issue.
Here is what I have found:
-new benz thermostat
-new benz coolant
-lines in and out of heater core are nice and hot
-blower works fine
The car will startup cold, with in 2 minutes I have heat. After 10 min of driving all of a sudden, the heat will die down sometimes slowly, other times quickly, and all I feel on my left hand is COLD air!
At this point I check the lines from the heater core, and they are nice and hot.
Any ideas? Maybe a blend door is broken? If so, would that be intermitten?
Please help, as it is beginning to be 30 deg. F mornings. (btw-the heat always was overpowering in this car before it acted up)
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
vaccum valve under the cowl behund the center firewall. where are you touching the lines to the heater core ? before or after the firewall?
cool. i will check that. i have a vacuum gauge i can use to apply vacuum to the diaphram. hopefully i will find a disconnected line.
i was touching the core on both sides, so i know there is sufficient flow.
i will check the valve tomorrow (monday) afternoon if i get a chance and let you know the outcome.
thanks
