Hello all,
This is my first post, i just bought myself a W220 to replace my IS200, and really got myself into trouble.
Didn't take an electrician to check the computers, when buying it was suppoosed to be just a accelerator pedal that needed replacing.
But when I took the car to the garage and got it connected to a computer, it showed so many problems, started looking at the computers and ESP seems like the box has been tampered with and Engine Control Unit (the computer at the far left if your looking straight at the bonnet) doesnt even have the casing so i dont know the number for the module, the evil people just droped the ECU without the casing inside. Messed with the wires got some wires soldered onto the circuit.
So the Engine control unit needs replacing as its throwing internal fault on the diagnostics computer, and it doesnt even have the casing. But i been trying to look for the module number and it seems like the "engine control unit" for my VIN number has 6 possible units:
My VIN Number is:
WDB2200262A248110
Posibilities:
A 170 545 12 40
A 170 545 12 40
A 024 545 33 32
A 613 153 01 79
A 613 153 02 79
A 613 153 03 79 (i have found this one to buy already)
There is a number on the ESP box which is:
A 031 545 09 32
If someone could help me on where i could find the numbers for the ECU i would greatly appreciate it, because i am loosing will to live with this purchase, one lesson like this teaches people how to buy cars in the future
Thank you
1997 E420 & E320
speak your situation to your dealer and see if maybe they will let you test which computer will work properly. It is unlikely since they usually have a no return policy on the ECM but it is worth a try. other than that you will need to find a good samaritan that will let you try out the computer from their car. where are you located, maybe I can help?
good luck
