C230K Sport Sedan
The heater & a/c fan/blower was working fine up until today. Doesn't matter what you set the rotary fan switch to, nothing comes on. When you turn the A/C on you can here it engage so it's not the A/C compressor and the fan doesn't work with A/C or heat.
I tried locating the fuse but there isn't a fuse specifically marked for the HVAC system but a few say tempamatic like 33, 37, etc. but they are all good. Do I have the the right fuse? Also, looking back at posts it says I may have to replace the fan or the switch, how do you get to this fan/blower?
C230K Sport Sedan
Discussion Starter #2
Doing some research I see that the blower motor, the blower motor regulator (resistor?) are the usual suspects and thanks to a good forum in the UK I can see how to remove these but how can I test to see which is causing the problem? There's no noise or smell or bright neon finger pointing me towards anything, just stopped working completely. Any help would be appreciated.
Golf R32 / Prev R170 SLK
Remove kick panel, 2 screw
Remove connector off fan motor
Remove cover under fan
Reconnect and put a volt meter on 2 spade terminals on motor to check for power there with ign on and fan on full
If ok then same as mine, brushes $35
If no volts check input to reg , brown to blue lead
Bazzle
C230K Sport Sedan
It started working again all by itself. Does that mean the motor regulator/resistor is what's going bad? Also, when the fan is on 5 is makes a whistling sound, at 4 you can't hear it.
Are the brushes something you can buy over the counter and do yourself? A whole new blower motor assembly is $132, the regulator/resistor is $102.
Bazzle
Is there an easy way to test this?. I do have a meter that I picked up but have never used one before and not sure about the settings
1998 , SLK 230
Multimeter? If you are just setting for power set the meter to over 15V DC , typically 20V full scale DC. Hold the negative probe to a clean (not painted) metallic component of the body and check for power with the +ve (red) probe.
