I had just purchased a 1999 s420 with about 93k miles when a neighbor decided to back his pick-up out of the driveway into my right rear door and rear quarter panel.
The body shop appeared to have done a very good cosmetic repair. However when I got the car home and pushed my key fob to lock the car, the lights blinked like usual, but none of the locks locked (4 doors + trunk). When I used the key to lock the driver door, the driver door only locked (other 3 doors did not lock). When I tried to lock/unlock the trunk I noticed the handle that sticks out does not project to lift up as it should. I do not have a front pass key hole to test.
Since the locks worked perfectly before, i believe the body screwed something up.
Questions
1) Is it likely the body shop caused this?
2) What is the source of the problem so I can at least direct them (I doubt they are MBZ knowledgeable)
In hindsight, I should have insisted in taking it to a MBZ shop instead of a insurance company "highly recommended" shop.
I plan to take it in to them this morning to take a look and appreciate a quick response.
Questions
