I have a ML320 and Im trying to remove the horn on the passenger side behind the bumper. I found S4toML's instructions but when i put the 13mm socket on that bolt in the center of the horn the whole assembly started to twist. The new horn came with a new arm (or bracket). I tried to unbolt the old arm (bracket) and it was impossible to get the socket in there. Any ideas?
can u elaborate on how u changed it? Did you unbolt the horn from the nut in the center of the horn? Or did u change the horn and bracket.
02ML320 & 06RClass (sold)
there was a bolt and a bracket included. But I only used the bolts and used the old bracket for my new ML55 horn. More or less "plug and play".
figured it out. Had to bend the bracket on the original one. Thanks guys! Saved me 70 bucks.
