95 C280, 89 300E, 94' E320 Coupe, 91' 560SEC
hey guys I am getting ready to reassemble my dash in the Car but I want to test everything out before I do so. I disconnected the vacuum pump in the back of the car back in march for diagnostic testing. You know the one located in the passenger reaer quarter panel with the two nozzles.
I disconnected mine so long ago that I forgot which cable goes where the Clearishwhite and the yellow cable. Can any of the C280 crowd that has the vacuum pump Number 202 800 1248 tell me which cable goes where? Its only two.
AKA
The nozzle on top closest to the three electrical connectors has the cable colored _______.
The nozzle farthest from the three connectors has the Cable colored____.
Thanx a bunch!
1983 300SD, 4 speed manual, 1994 C280
Hey man I haven't had a chance to check this out again but it seems to me the black hose and the clear hose were connected side by side at the bottom on mine. Then there are the five (5) yellow ones at the top.......:bowdown:
Hmm you might have the other Hella Vacuum pump I have seen on the Web. Different pumps were used for different applications in cluding some with a vacuum distributor block connected directly to the nozzle. Thanks anyways. I found out that the Yello Central Locking system belongs to the top and the White A/c supplemental system belongs to the rest. Thanks!
