2012 E350 4Matic; 2008 S550 4Matic; 2014 E63s
Hi,
The left front fog light (round light that comes with sport option if it makes a difference) is stuck on. Car is off, rest of lights are off. Turning rest of lights on/off including fog lights works fine, but the left front fog wont turn off. I don't see fog lights (or headlights for that matter) on the fust chart. Is there a fuse I can pull until I figure out the source of the problem? Any suggestions?
Also - how do I get to the rear battery to recharge it?
Discussion Starter · #2 ·
Never mind - found non-factory "repair" circuit wired direct to battery with its own fuse. Not sure what prior-owner was trying to "fix". Also found charging point for rear battery under cover next to starter battery.
