2001 ml270 cdi
Im in log cabin now after 6 hour drive to bond with my 2001 ml270cdi. The trip was not without incident as the car stalled twice when pedal to the metal. First merging to the highway. Second when overtaking uphill. Power just cuts and as i roll to side of road all warning lamps come on. I just restart car with no problem whatsoever. Is this turbo, transmission or fuel line issue?
Next, halfway through the trip im now hearing a slight rattle noise in the engine when i hit 1600rpm. No power loss or warning lamps however so i hope i can still drive this home!?!?
Lastly, my fuel tank cover wont open even if car is unlocked. Can i override this?
Appreciate expert opinions as i need to get home through another hi speed 6 hour drive in 2 days pls
ML 270CDI 2002, BMW K1300S, VW POLO 1.9TDI
Power cut could be due to a drop in rail pressure when you floor the pedal. High pressure sensor or pump?
Mercedes ML 270 CDI 2002 Facelift, Right hand drive, Off road tires, Lifted, Comand retrofit.
Power cut during hard accellaration could also be due to a diesel filter that needs replacement.
2001 ml270 cdi
Will do friends. Rail pressure sensor, pressure reg valve, filter changes and cr pump work = $1200 but i love the m270 cdi still sigh
