I'd appreciate any help with this:
I bought an aftermarket power antenna to replace my broken stock one (95 S500 sedan). The stock unit has a wiring harness with 4 wires: blue, black, red/white and brown.
The blue goes to the splitter, which I don't need and won't be using. I would presume that the black is earth, the red/white is positive, and the brown is the signal from the radio. Can anyone confirm that with certainty?
Also, the stock unit has an earth (ground) cable going from the metal antenna directly to the fender. My new antenna doesn't have a mounting point for this and I'm wondering how necessary it is since it's grounded through the other wiring (the black wire).
Thanks!
Mike
Thanks!
Mike
