1 - 1 of 1 Posts
My car started misfiring on the odd numbered cylinders and I thought it was the coil pack. After tearing everything out I found out that my valve cover gasket on the passenger side was leaking, and remembered that a member here said he also had a small leak and it was shorting out his coil pack. I looked into the spark plugs holes and sure enough there was oil pooled around them. Anyway, there is an air hose ( I assume) that crosses over the coil pack. In the video I was watching, the guy had a worm clamp around it that he could loosen. I didn't have those, mine has some weird clamp that you can't unscrew. I tried to pull the hose off of this canister that sits towards the back of the bay under the intercooler and broke the nipple that the hose was connected too. I can't for the life of me find out what that part is. Anybody have any clues? Any help would be appreciated.
EDIT: I found the part number.
1 - 1 of 1 Posts
