1 - 1 of 1 Posts
1982 300SD, 1984 380SL, 1997 E320, 2008 R350
2008 R350 Both idler pulleys and tensioner are new. So is the water pump. Squeal, like loud cricket chirping, appears to be coming from upper idler but when I install old one it sounds the same. Squeal is most pronounced when engine is cold. Could this be the new aftermarket water pump? I tried using metal bar as statoscope on bolt heads of two idler pulleys but heard nothing like the squeal on them. I can’t do that to rotating hubs like water pump, alternator, ac & steering pumps but the noise appears to be coming from opposite side of drive belt at upper idler.
1 - 1 of 1 Posts
