1 - 11 of 11 Posts
1979 116 300SD Turbo Diesel Mint.
Hello everyone. I need some parts for my 1979 300 sd turbo diesel 116 chassis ASAP. I need the following: my first priority is Radiator!! so that's number one!. Radiator mounts, Power Steering pump PULLEY, AC condensor & fan, Fan Clutch, and Fan. Thank you very much. I hope to find some parts this week... crossing my fingers. :p
73 280SE 4.5, 71 300SEL, 03 BMW Z4, 72 Fiat 850, 80 Triumph TR7, 85 Porsche 911
Parts are everywhere and relatively easy to find. Try Napa Autoparts, Kragen, Checker, or a local parts guy. I've had great luck with Napa for W108 parts.
Also, look at Adsitco.com, peachparts.com, or do a general google search for your car.
Super Moderator
85 Audi Coupe Quattro, 85 Audi Coupe GT, 71 BMW turbo 2002, 73 BMW 2002tii, 85 BMW 635csi
Avoid adsitco like a full cavity search.
I spent my friday going to 3 different pick n pull wrecking yards to only find a 116 450sel which had a completely different radiator than the diesel. And I also did not find a similar radiator on the 300cd models either for my 116 diesel... so the parts arent too common around here... unless i'm just not looking close enough. I located a used rad at a auto dismantler in oakland for 250... i think that's steep for a used... but if i have no other opions than... :crybaby2: So any help at all will be appreciated. I will check out those websites as well.
90 300 SE ,85 300 GD
Gas W116 models vs. DIESEL W116
Most of the mechanical for A/C, cooling/transmission parts are NOT going to work. Trim parts, yes. Try the Classic Center in Irvine, CA if you really get stuck. 866-622-5277.
Another option is to have your present rad and oil cooler ra-cored. I haven't got a clue what the difference in price between a recore and new would be though.
1 - 11 of 11 Posts
