1 - 9 of 9 Posts
1985 500sel and 500sec 2012 E63 1989 Porsche 911
ok heres where ive gotten for the gear removal
got the wood off completely, unscrewed the 2 screws at the base of the shifter, and dont know what to do next, theres to bolts at the bottm, not sure if i take those out too??
also whts this plug thats next to my finger
Discussion Starter #2
ok , im really frustrated now, i cant seem to get the gear box out anywhich way i pull or try, i cant seem to access the bolts down at the bottom of the box, not sure if thats what im supposed to go after. the 2 on the left side are totally hidden because of the big black plastic that runs along the side of the console,
im so lost
2008 S550 designo
You need to get the top of the gear box off - the part that has the PRND... There should be 4 tabs on the sides that when pushed in will allow the top plastic part off. ove it up and rotate around the rod and you can access the parts inside. If memory serves, there are a few parts under the PRND piece that need to come out also.
tw
ive been trying all day to get the top of the gear box off, there were 2 tabs on the left side that i got off, but on the right, its not identical, theres some sort of long tab or something but it dosent go anywhere.
those 2 screws i see in the pic, i removed them, but that didnt do anything, there are 2 brackets that those scewes went thru but i coundlnt get them out.
1990 SEC
The procedure that Twalton describes is correct.
As far as that switch is concerned, I did not recognize it (my car is a 1990 SEC). Sorry.
ok, so i will go take out those clips again, on the left hand side, but they are not identical on the right. ill take a pic and sho u.
it really looks like that the box is one unit and the top wont just pop off??
the other screws im talking of, are in my second pic, even when i did remove them i got now where
thanks all
2008 S550 designo
Hey vdub,
How have you made out with your shifter replacement? Still having problems removing the top of the gearbox?
Trey
havent had a chance to get back at it, ive been on call at the hospital alot , and i had to put the console back so i could plug in the windows so i could drive, probably in a day ill go at it again, thanks
1 - 9 of 9 Posts
