hello there, im planning to change my fuel filter. So just wondering if its a tough job?? do u have to drain the fuel? i have no idea.. never done one before. Anyway and helpful advice wold be greatly appreciated
thanks
Put a few rags underneath your car, and under the fuel filter, unscrew the old one, and pop your new one, clean the slight mess you might of made, and your done
On a gasser you have to put the rear end on stands or ramps. Then just unbolt one end of the filter and then plug it with your finger, then unscrew the filter from the other side and then hurry and put the new filter on and bolt it down. I believe the nut is a 17MM. Good luck
