1 - 1 of 1 Posts
Hi forum.
I've tried to find the Caliper model/nr basically anything related to the Calipers, so I could rebuild them.
What I could read out from the calipers is:
ATE R79 214R (80) 22R
It's a 4 piston type
Maybe someone more experienced with Mercedes break systems could read out something from the numbers.
I recall the calipers looks something like an old Mercedes type, looking at the caliper you kinda can see a Circle probably the Mercedes star.... W124? or even older.
Interestingly they have, if I remember correctly, at least 5 or 6 Bleed Nipples and as well 2 fluid lines going to each caliper.
In the pictures below, it's 1 left-side front Caliper that i have just split in 2 pieces.
I believe you, forum members, being true Mercedes enthusiast could help me find out some info about the calipers.
Some hints, info, sites, old books, brochures - you name it.. What ever there is, to determine the part number.
Thanks in advance!
2608195
2608196
2608197
2608198
2608199
2608200
2608201
2608202
1 - 1 of 1 Posts
