1983 Mercedes 280SL
This is an odd one.
Was speaking to an R107 expert at a classic car show, I explained that the ABS light in the dash never goes out and assumed that it's a big deal. He said the problem is almost certainly a 'blown blade fuse above the passenger footwell'. He explained I need to remove the cover beneath the glove box, said something about relays, replace blown blade fuse, job done.
Definitely not anything under the carpet. I had a look, saw some relays (pictured) cracked the bastards open, no fuse. Can't see anywhere where there might be a fuse.
Any ideas??
Any help much appreciated.
1997 SL500- 40th Anniversary
It Is What It Is, Dude
decampos...Here's a pic of the OVPR in situ for a 560SL...Your relay is different though, and I don't know that it's in the same spot.
Ears....His early style OVPR doesn't have the fuse.
1983 Mercedes 280SL
Thanks for the replies. Helpful stuff. Thanks to this thread it is indeed the 'early type' OVPR I have. Yep, doesn't have a fuse in it. Should I try and source a new one? Is there a way to test it to see if it really has failed?
Any help very much appreciated.
Cheers
