2001 E430
Hello guys,
try this one. I changed the CAT last week and recently changed the MAF. all is 1000% better idles great at or around 500 rpms at idle etc etc... I recently noticed a slight rev of engine at start up. it goes to about 1000 then real quickly goes to 1500 the drops fast to 500 and stays there. it drives fine???
I think before i changed the CAT and MAF it reved a liitle at start but not like this with the slight quick jump. Do you think this is bad??? I did not change the O2 sensors nor the fuel filters witch i plan to do..... I quess it could be the O2 sensors????? ANY ADVICE..
thanks
chris
You have an E430 and I have a E320 but: when my engine is cold, the RPMs go up to 1200 and pretty quickly drop to 800; that is when I always start driving. Once the engine is up to 80 C then it idles at 500. How was your cold engine behaving at startup before you chaged the CAT and MAF? Yours sounds pretty normal to me.
2001 E430
Same in winter??? with the CAT issue before i changed it the engine was stalling. That is 1000 % better now along with me changed the MAF, The revs i guess are just like yours. I also get a slight hesitation in traffic when i have to stop real quick and then excel caant tell if its ox sensor or fuel filter??
No, mine is not quite the same in winter but close to what I told you earlier. It just takes a bit longer to get up to 80 C and that's about as high as the temperature ever gets. In warmer weather it will get to 90 or 100 when I'm driving.
I don't know what's causing your hesitation but if you are patient, one of the experts on here will help you troubleshoot that.
