1 - 12 of 12 Posts
S280 ,another s280,turbo 500 SEL bountyhunter beachbuggy,59 ford pop,vito
I drive a 1995 s280 with a 2.8 straight six and have just blown the diff (or think so anyway)
Now this is where you knowledgable and kind hearted chaps come in
1 Now have i blown my diff ?
The car was sitting at the lights waiting for them to change to green which they duly did and when i went to set of there was an almighty bang from the back of the car
Under the car looking at the diff etc i have the prop shaft spinning and 1 driveshaft also spinning but obviously no drive forwards
2 Is there any other car in the mercedes range that uses a diff which i can replace my diff with short term as i will not get a s class diff in time to fit it before xmas
My local scrapyard /vehicle dismantlers has 80s and 90s c class e class etc in( if they fit) so could get 1 for pennies and then get the proper diff later when all the snow has gone and deliveries are back to normal after the xmas rush
Any advice and help appreciated
Cheers Ian
'08 E63 AMG Wagon. C280 (320) track/drift slag. Wife has CLK500 Convertible
I very much doubt a diff from a smaller car would fit, but if you need one fairly quickly, give Carl a bell a W140.co.uk
Carl is my back up for a diff but the postage system in the uk is seriously messed up at the moment due to the snow so if an e class diesel or any of the cars in the scrappy that has a 2.8 motor that would fit that would get me back on the road tomorrow rather than weeks time
My car is sitting 2 miles from home at the moment with the hazards on waiting for a mate to come and tow me home !!:(
I know i'm clutching at straws but i was hoping the diff was the same in the e class and they just made the driveshafts a different length to suit the bodyshell etc and maybe used the same cv joints too to save money
Okay the gearing could be different but i can live with that for now
Phoned Carl for advice and to see if he had a diff or could advise me of what i could do and he's away on holiday for the next 10 days :( so i guess i'll be of to the scrappy for a look at diffs then
Good job it's only minus 7 outside:eek:
Anyone got an exploded diagram of the diff ?
Well i've got the car home and had a look underneath and the diff isn't knackered after all it would appear i have ONLY snapped a driveshaft:)
Now i just need to find another drive shaft and get it posted to me so it arrives before xmas
2011 GLK,2007 S550,2003 S55,2008 CLK,2009 C300,1996 E300,2005 E320,2002 E3
My son did this to my w126... It was the 1/2 axle on the drivers side
Will be off to the scrapyard tomorrow with all manner of spanners ,allen keys and measuring devices to see if i can get a driveshaft ,failing that i will be breaking out the welder and sleeving the break for now
w140 s500 1994,w123 230c, w123 280ce etc
i may be able to help but cant check until the morning if i have one or not if you pm me your chassis number i will have a look for you when i get in to work tomorrow.
Discussion Starter #11
Cheers
Reg no is M216 RTG
Vin no is WDB1400282A244568
Registered 22/2/95 so could be a 94 or 95 model
Driveshaft has the abs cutouts in it
just had a look and the ones i have are from an s500 and dont have the abs ring on the end im afraid
sorry i cant help
call pete at damas 01246822939 tell him leigh at germanspares gave you the number he may be able to help
1 - 12 of 12 Posts
